Author Topic: Possible VC-10 into BFS this evening  (Read 3484 times)
« on: January 05, 2010, 06:33:08 PM »
What sounded like a VC-10 landed at BFS at approx 1805 approx-ATC told the aircraft to park on 25A-they also requested his REG which makes me think it was a military aircraft.
Unfortunatly with my rather basic airband radio,I was unable to hear it`s response
I only noticed it arriving because it sounded different-slight whistle of the aircraft,and I only got a brief glimpse as it passed behind our shed.
Will know later when it goes out,cause the windows will shake :D
« Last Edit: January 06, 2010, 12:19:17 AM by Angry Turnip »
Offline Nige
  • Flying Officer
  • Local Airport: Aldergrove
  • Favourite Aircraft: Too many to list !
Re: Possible VC-10 into BFS this evening
« Reply #1 on: January 06, 2010, 11:13:50 AM »
Hi, can confirm that it was a VC 10, as it is still parked up at stand 25 at the International airport. It is parked there as there is no longer an RAF visiting aircraft servicing facility since the handover of Aldergrove to the Joint Helicopter Command
Nige
Offline Nige
  • Flying Officer
« Reply #2 on: January 06, 2010, 11:15:44 AM »
Sorry guys, forgot to mention that the VC10 is still there, as of 11:15.
cheers Nige
« Reply #3 on: January 06, 2010, 01:20:49 PM »
I thought that`s why they parked there,thanks for the info Nige;I confirm my windows are still intact  ;D  so I thought it might still be on stand.
Offline Nige
  • Flying Officer
« Reply #4 on: January 07, 2010, 12:57:23 PM »
Hi fellas, just found out that the VC-10 was diverted to Aldergrove from North Sea.
Nige
Offline Nige
  • Flying Officer
« Reply #5 on: January 20, 2010, 09:39:06 AM »
Wee update with regards to the VC10 at Aldergrove, apparently the aircraft was stuck here for a few days because they were refused fuel. !!!
« Last Edit: January 20, 2010, 09:39:49 AM by Nige »
Hammerhead
  • Guest
« Reply #6 on: January 23, 2010, 06:56:27 PM »
« Reply #7 on: January 24, 2010, 12:27:27 AM »
No I don`t think it was-What I heard was it diverted into BFS due to the extreme cold and the aircraft was having problems with it`s on board anti-icing equipment.
I heard the crew talking to ATC after they had landed and they said ice was building up on the wings leading edge.
Hammerhead
  • Guest
« Reply #8 on: January 24, 2010, 09:46:56 AM »
It seems a bit of a coincident that they suspended the passenger carrying around the same time.....  i suspect that the problems that the one that landed at BFS probably affected more than one aircraft.....  But then again they are 43  years old ... would you fly with a airline that operated aircraft that old??   i know i wouldn't....
« Reply #9 on: January 24, 2010, 03:49:03 PM »
I understand your concerns but the aircraft diverting into BFS was operating as a tanker and wasn`t carrying passengers-they have a duel role and can carry passengers (troops) and carry out tanker duties.
The suspension of (passenger)troop carrying is only a temporary one,and is nothing to do with the airworthyness of the aircraft.
It wouldn`t bother me in the slightest to fly in a VC-10,I have been lucky enough to fly in them in the past.
Would you not fly in a Spitfire then?  ;)
« Last Edit: January 24, 2010, 04:39:51 PM by Angry Turnip »
