Author Topic: Help required on purchasing binoculars  (Read 3431 times)
Offline RNASMU
  • Favourite Aircraft: Too many
« on: November 17, 2010, 05:13:09 PM »
I'm hoping Santa will bring me a pair of binoculars for Christmas and was looking for some advice.
As well as viewing flights to and from the International and the Harbour, I would also would like to view transatlantic aircraft.
I'm not sure if 12x50 or 16x50 would be sufficient for viewing transatlantic flights. Can anyone advise. Thanks
Ian
Offline S61N
  • Favourite Aircraft: Sikorsky S-61N
Re: Help required on purchasing binoculars
« Reply #1 on: November 17, 2010, 07:23:01 PM »
I got a good pair of Trikon 10-30x50 in Argos a few years ago - not too expensive either.Gives you a bit of range with magnification like a zoom lens.Easily see the tails of the biggies going overhead on a clear day  8)
Something similar to these if you shop around.
« Last Edit: November 17, 2010, 07:28:30 PM by S61N »
Offline biggles
  • Flying Officer
  • Local Airport: belfast city
  • Favourite Aircraft: hawker hunter
« Reply #2 on: November 18, 2010, 08:11:17 AM »
hi like all things it depends on your budget and type of binos you want,i have had a pair of cannon i.s 10x30 these are really good for watching high level aircraft.
they are also stabilized so the aircraft do not wobble while you are trying to identify them.i use them almost on a daily basis for work and after using these you wont want to use ordinary binos again.
sadly the prices range from £350 to £1000 for bigger units.
Offline RNASMU
« Reply #3 on: November 18, 2010, 12:00:20 PM »
Thank you both for your help
Ian
