Author Topic: Dublin Airport - Best Location  (Read 8343 times)
Offline Chris0423
  • Local Airport: Belfast City
  • Favourite Aircraft: EF-111 Raven
  • Camera Used: Nikon D7200 & Sigma 150mm-600mm + x1.4 teleconverter.
« on: December 17, 2017, 11:53:35 PM »
Good evening folk,
planning a trip down to Dublin Airport for some photography, weather permitting over the christmas break
can anyone advise the best location?
thanks in advance.
chris.
« Last Edit: December 19, 2017, 10:54:43 PM by Chris0423 »
Re: Dublin Airport - Best Location
« Reply #1 on: December 18, 2017, 12:42:17 PM »
There are a few good spots to use,the long stay car park parallel to the main runway is good,and you can climb up the bank to get a better view-not sure how much it is to park in there,but it`s secure.
There are other area`s around the airport,but be careful not to block any crash gates or access.
The USA flights usually come in early,mid morning is Ryanair Fest.Beware of the passing lorries and buses,that can ruin shots.
Doubtless if you search for EIDW spotters you will find some useful info.
« Last Edit: December 18, 2017, 12:42:53 PM by Angry Turnip »
Offline Mark Woodhead
  • Squadron Leader
  • Local Airport: Dublin
  • Favourite Aircraft: 757
« Reply #2 on: December 18, 2017, 01:47:11 PM »
At this time of the year with the sun low in the southern sky the only place for good photography is the south side of the main runway. On this road there is a layby below a grass bank, which is good for take off and landings. It can become very busy with no places available, but usually with patience there shall be somebody leaving. Beware climbing the bank as it is steep and can be very slippy. If you have a short 2-3 step ladder the additional height can be advantageous to avoid the top of the fence in take off pictures.
If it is cloudy you can get good on the ground shots of aircraft turning off the east end of the main runway fom the road on the north side of the main runway. Here you shall need your short step ladder for shots over the fence.
Now the second runway work is in progress the location on the west side of the short runway with landings from the north is no longer available.
Hope the weather is good.
Offline Chris0423
« Reply #3 on: December 19, 2017, 10:58:57 PM »
AT and Mark, genuinely very much appreciated information. many thanks indeed.  fingers crossed for some clear skies.
Chris.
